Finding an amp for 2 10" subs
Old Mar 30, 2007 | 08:04 PM
86 5.0L's Avatar
86 5.0L
Default Finding an amp for 2 10" subs
Hey guys, let me start off by saying am a noob-in-training when it comes to advance audio, simple speaker hookups I can handle, but I just keep getting confused with this;
I have two 330RMS 10" Sony subs I wanna hook up, I *THINK* I need a 2-ch amp with a RMS rating of ~650-700RMS correct?
Also I have the stock 86 "Premium" stereo still in the car and its staying, since I dont have pre-amp outputs, I also need a speaker-level input on the amp?
Old Mar 30, 2007 | 08:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Finding an amp for 2 10" subs
For number of channels all depends. Bass is bass. You normally want to run that in Mono/bridged off of an amp. If you get a Sub specific amp it will have a built-in high band adjustable cut-off so you won't need an addtional crossover for your subs. Mono amps are usualy designed specifically for a subs so they tend to sound best than a two channel (stereo) amp that is just bridged for single channel.
Also, consider how you want to hook up your speakers, series or parallel.
Preamp is recommended but some amps have built-in line-level adapters so it may not be needed. Find your amp first then see if the pre-amp is needed.
Old Mar 31, 2007 | 01:51 AM
86 5.0L's Avatar
86 5.0L
http://www.crutchfield.com/S-GB05d2G...=158XM9001#Tab
mono amp, looks like hooking them up in parallel would be best, also has the Speaker Level Inputs and Preamp Outputs
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
