Alpine or Kenwood?
Old Apr 10, 2007 | 12:24 PM
PReal's Avatar
PReal
Default RE: Alpine or Kenwood?
All the edi stuff in 6.5 inches. I would double check the size of the stocks. If all else fails, run a 5.25 comp set.
You will want to upgrade the subs also. A 4 channel amp and a sub would work witha set of comps.
The sound deadening would cover the outer door skinand the inner door skin.
Old Apr 10, 2007 | 01:38 PM
art02gt's Avatar
art02gt
ORIGINAL: PReal
So if my speakers are 6x8 or 5x7, can i make them fit or will they only fit if they are 6x8? and where in the site will ED make a custom baffle to mount the woofer and tweet in the 6x8 location.
Old Apr 10, 2007 | 08:52 PM
laserred38's Avatar
laserred38
6x8 is basically the same size as 5x7. you can make the 6.5s fit NO problem. many people are running 6.5s in 5x7 locations. i would drop down one notch on the components, add some sound deadener, and get a new sub and box. then get the 4 channel amp. Preal know what he is talking about. listen to him.
Old Apr 10, 2007 | 09:30 PM
art02gt's Avatar
art02gt
ORIGINAL: laserred38
So what you're saying is that 6.5" will fit right in? no custom work needed? Because that would be great.
Old Apr 10, 2007 | 10:02 PM
laserred38's Avatar
laserred38
noo. you still need an adapter plate. but other than that they will fit. they won't just bolt right in.
Old Apr 10, 2007 | 10:56 PM
PReal's Avatar
PReal
I have helped a number of people on this forum through installing 6.5 comps. It is really pretty easy.
Old Apr 10, 2007 | 11:43 PM
seight311's Avatar
seight311
The Mustang 5x7/6x8 opening is big, if there is any trimming needing done, it's minimal in order to get some 6.5 components to fit.
Old Apr 11, 2007 | 06:16 AM
ttocs's Avatar
ttocs
you do not need to trim it for the 6.5's if you use a 1\2" mdf baffle. I have done it a million times in a mustang and never had a problem.
http://www.cardomain.com/ride/2081149/2
Here is how I did them in my truck with a simple enclosure.
Old Apr 11, 2007 | 07:33 PM
art02gt's Avatar
art02gt
ORIGINAL: ttocs
What is that material you made the baffle with? Where can i get it? Ever worked on a new edge? If so how hard is it to get to the front speakers?
Old Apr 11, 2007 | 08:16 PM
seight311's Avatar
seight311
MDF as he said in that post you quoted.
