Should I Use a Capacitor?
Old Apr 10, 2007 | 06:08 PM
  #21
SoulBurn18's Avatar
SoulBurn18
Default RE: Should I Use a Capacitor?
ORIGINAL: seight311
You cant (shouldn't) just add a tweeter, you need a crossover. And the ones built into the mach amps, is junk. If your going through this much you might as well get a component system. Or just leave your Mach tweeters in for the time being.
Ideally what I'm hoping for is that I'm happy with the mach 460 system with the addition of the 2 JL Audio 10's and 1000 watt amp. If not, I'll start looking at gutting the entire system and starting fresh. I've already gotten compliments on how crisp and clean it sounds since I added the new head unit so I'm hoping just adding some more bass will complete it (wishful thinking).
Old Apr 10, 2007 | 08:19 PM
  #22
seight311's Avatar
seight311
Yeah Just adding a head unit can make a big difference with the Mach system.
Old Apr 10, 2007 | 08:27 PM
  #23
SoulBurn18's Avatar
SoulBurn18
ORIGINAL: seight311
Yeah, it sure did. The only downfall is that it killed about 80% of the bass. Everything else sounds incredible.
Old Apr 10, 2007 | 10:07 PM
  #24
laserred38's Avatar
laserred38
if your amp is sending 160x2 to each sub, it is not a 1000 watt amp. it might say it on the front. but it isn't. probably not even 1000w Max.
Old Apr 10, 2007 | 10:28 PM
  #25
SoulBurn18's Avatar
SoulBurn18
ORIGINAL: laserred38
The specs on it's 1000 watts peak power. It pushes 170 watts RMS to each of the 2 channels so that's all I care about. It's enough to do what I need it to do and then some.
Old Apr 10, 2007 | 10:43 PM
  #26
PReal's Avatar
PReal
ORIGINAL: SoulBurn18
Word, when you decide to upgrade, that amp would be great on some comps.
Old Apr 10, 2007 | 10:46 PM
  #27
SoulBurn18's Avatar
SoulBurn18
ORIGINAL: PReal
VERY TRUE!!!
Old Apr 10, 2007 | 11:16 PM
  #28
laserred38's Avatar
laserred38
then refer to the amp as a 170x2 amp. and not a 1000watt amp!
deebo68
Apr 22, 2007 01:21 AM
Civic4doorsleeper
Mar 5, 2007 01:33 AM
MARK1983L
4 Cylinder NA and Turbo
Jan 15, 2007 11:12 PM
ADRIAN1
Nov 27, 2006 10:46 AM
smbikes
Oct 16, 2006 03:19 PM
