installing system.. question
Old Apr 15, 2007 | 10:23 PM
eddiev22's Avatar
eddiev22
Default installing system.. question
okay, i have everything set up, i just need to get a line converter and a power line.. but for the remote start, is there an alternate power source, where should i run that wire to? also, the power cable should be run where to look the neatest?
basically:
-where should i wire the remote start to
-how should i wire the power wire (go through where , etc, remove backseats for install?)
thanks!
Old Apr 15, 2007 | 10:31 PM
ttocs's Avatar
ttocs
Default RE: installing system.. question
you can run awg through the grommet on the drivers side with no problem, 4 awg if you push harder. You can go to a +12v switched fuse at the fuse box or behind the radio.
Old Apr 15, 2007 | 10:41 PM
seight311's Avatar
seight311
You mean remote wire I assume, you connect it to your blue wire with the white strip through it coming from your head units harness. And theres info on where to run your power wire, not power line, in your car in the Information/FAQ thread sticky.
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
whatsup62
Aug 29, 2015 01:25 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
