mach460 with aftermarket amp/subs
I have the mach460 stereo and i think it sounds fine but needs a little more umph! I was thinking of installing an amp and 2 subs. It doesnt have to be a huge amp or subs as i just want more bass. Amp will be running 2 subs only.
I think MD has or had something like this done. Am i correct? Any recomendations for an amp and subs? Want one that sounds good, not overly priced, and like i said doesnt have to shatter my window.
Do i need a line out converter? Will this one work?
http://www.audiooutfitter.com/store/LOC80.html
Thanks,
Rob
Thanks,
Rob
RE: mach460 with aftermarket amp/subs
yea just a LOC and amp kit and your set, space is tight under the factory amp rack so if you wanna put the subs there in a box its gonna need to be low profile. I had a fiberglass box made into my spare tire well, I took the spare out to save weight anyways.
ORIGINAL: mdvaldosta
about 8#'s for the subs and amp, another 5# for the fiberglass - already had the spare tire crap out (about 30 - 35 #'s)
so, about 15#'s for everything ain't bad - bout the same as a big ****
Well i was actually thinking about stealing MD's idea and taking out the spare and sinking them in. Hey MD did you try this without the fiberglass at all? Will it sound like crap if i just cut 2 holes in the wood panel thingy and sink the subs and add insulation in there?
if you did that it wouldn't be air tight, I suppose if you got something that would work in a free-air or big ported box type sub then maybe yea. fiberglass was easy though - just get a thin piece of board, like 1/4" and lay it over the opeing with your holes already cut outta it, lay the fiberglass cloth over it and spread the reisen in and let it sit for a few hours. Piece of cake.
Dan04COBRA
09-30-2015 11:46 AM
09-24-2015 09:18 PM
09-17-2015 07:32 PM
