Help with aftermarkt HU and amp
o.k. i have a question i have an alpine head unti with i set of rca's my car has the mach 460 in it and some of the plugs i have seen to use the 460 with an aftermarket headunit use this rcas is there another way to hook the head unit up to the 460 and still be able to use the rca's to power my memphis 1500d. Can i use this and still be able to run the alpine head unti and have my rcas open for the memphis amp Will this work?
http://www.crutchfield.com/S-3kSv5dZ...mp;I=142C4FDK5
I think he is asking if there is away he can use the factory amp, im guessing for the front and rear speakers, and still use his RCA outputs for his subwoofer, and if the item he posted would be the piece that he would use to do that.
check out page 2 of my sig. you should use the speaker level outputs of your deck and bypass the factory amp(which is easy). You can use the factory subs then if you want but if you are putting in a set you will not want the factory set playing........
breaking
Oct 2, 2015 01:27 PM
