broken antenna, kind of...
Old Apr 20, 2007 | 05:30 PM
samseed101's Avatar
samseed101
Default broken antenna, kind of...
When installing a new headunit last summer, I acidentally pulled too ahrd on the factory head unit when trying to unplug the antenna. Well the tab broke off in the headunit, thus preventing me from being able to plug the antenna back into my new headunit. This leaves me without AM or FM on the car. It hasn't been a major problem because I still have the CD / MP# capabilities as well as XM radio. But I would like to know if there is a way to cut the antenna and add another plug to it so that I can use it again.
Is that possible? If so, is it expensive or worth the hassle? Is there any other solution?
Old Apr 20, 2007 | 05:49 PM
seight311's Avatar
seight311
Default RE: broken antenna, kind of...
I don't listen to the radio so I never have mine hooked up anyhow. I have never cut into an antenna cable so Im not exactly sure whats inside. ttocs may be more helpful on this.
Old Apr 21, 2007 | 11:25 AM
ttocs's Avatar
ttocs
as long as there is enough length, it is not a big deal to solder a new end on if you know how to use a solder iron. For some reason I am thinking though that there is a disconnectable piece in the SN95 like you and I have and you could simply pull the bad piece out, solder it outside of the car and the put it back. The only other way to fix it would be to replace the antenna. If you reaplce it at the fender it would be a little bit of work to mount it and re-run it. You could however get a strip antenna as it is made to be stuck up under the dash or out of site.
Old Apr 22, 2007 | 02:36 AM
samseed101's Avatar
samseed101
I may go with the strip antenna idea. Thanks for the help!
Old Apr 23, 2007 | 09:21 AM
ttocs's Avatar
ttocs
it will be the easiest to be honest and reception is only slightly worse then a normal antenna.
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
ChampInSD
Oct 2, 2015 04:55 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
