Mach 460 Problem (yes another one)
Old Apr 21, 2007 | 06:45 PM
JDWalton's Avatar
JDWalton
Default Mach 460 Problem (yes another one)
Hello all,
I have been searching around alot and have not found a answer yet, though I have found similar if not Identical Questions.
Problem:
I do not get any sound from my stock Mach 460 sound system, UNLESS I turn it all the way up, then you can faintly hear sound through the tweeters
Back-round:
I used to have a Pioneer radio in there, with the line level converter to make it work with the Mach system
All my stereo Equipment was stolen while I was deployed in Iraq (all factory components left)
I put my factory radio back in and now have the problem. The only difference is, it was the system with the separate CD player which I no longer have. Does the system with the CD player in the second slot stock, need to have the CD player in to work due to any wiring?
Troubleshooting done:
Unplugged each speaker one at a time to make sure none were bad
Checked all connectors to make sure they were good and not lose
Checked fuses
I am pretty much stuck now, any help would be appreciated.
Old Apr 21, 2007 | 07:25 PM
ttocs's Avatar
ttocs
Default RE: Mach 460 Problem (yes another one)
what year?
What speakers are playing? the tweets or the woofers?
Old Apr 21, 2007 | 08:31 PM
JDWalton's Avatar
JDWalton
its a 98, and as the problem states, you can only hear sound faintly through tweeters.
Old Apr 21, 2007 | 10:54 PM
JDWalton's Avatar
JDWalton
anyone?
Old Apr 22, 2007 | 06:10 PM
JDWalton's Avatar
JDWalton
/bump Am I screwed?
Old Apr 23, 2007 | 01:45 AM
Grizzel's Avatar
Grizzel
You might need the CD player I have a 2000 and have the Tape/Radio in the top deck and CD player on the bottom. If I remember you need the CD player for the stock amps to work. I had the same problem. Your best bet is just buying a cheap headunit because I think the stock CD player runs a lil over 100 bucks
Old Apr 27, 2007 | 08:28 PM
JDWalton's Avatar
JDWalton
Hey, had my parents dig my old CD player outa storage and mail it out to me, radio works like a charm. Thanks for the help guys
Old Apr 28, 2007 | 12:40 PM
ttocs's Avatar
ttocs
I would wonder if the tweets are not blown.
Old Apr 28, 2007 | 01:16 PM
JDWalton's Avatar
JDWalton
??? just said it works good now, I needed to put the CD player in becuase there is a diffrence in the stereo wirring harness between ones with and without a cd
Big Al's 03
Sep 16, 2015 07:31 PM
Big Al's 03
Sep 15, 2015 09:05 AM
TimeLord101
Sep 4, 2015 09:27 AM
iamgobono
Sep 3, 2015 12:37 PM
