Switch the high and low beams
Old Apr 25, 2007 | 04:11 AM
DJStile's Avatar
DJStile
Default Switch the high and low beams
Hey guys...I recently purchased and installed the Stangmods bi-xenon headlight HID kit. The kit works great, except for one problem. When I turn on the headlights, the HIGH beams go on and when I click the stick (that normally toggles between low and high beams), the LOW beams go on. I tried altering the HID harness, but it doesn't do anything so my question is this. Is there any way to change something around on the STOCK wiring harness or anywhere in the car to switch the neutral position of the toggle stick with the "clicked" position (i.e swap the low and high beams of the toggle stick)?
I know this sounds confusing, but I am having trouble explaining it differently.
Thanks for the help!!
Old Apr 25, 2007 | 02:33 PM
ttocs's Avatar
ttocs
Default RE: Switch the high and low beams
you should be able to either switch the input into the HID, or the output out... What is stopping you? Does the company that made them have tech support?
Old Apr 25, 2007 | 02:34 PM
DJStile's Avatar
DJStile
They do and I followed the instructions to change the high and low wires on the HID harness but it didn't change anything...I'm not sure how to change it on anything stock
Oct 7, 2015 07:02 PM
Colin Ringle
Sep 15, 2015 09:27 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
uedlose
Sep 10, 2015 03:30 PM
