remote turn on
Old Apr 27, 2007 | 03:47 AM
seight311's Avatar
seight311
Default RE: remote turn on
You cant see it from your pictures you need to basically take a picture of the harness coming out of your aftermarket cd player.
It's really simple, it's mainly blue with a thin white stripe though it. Alot times it even says remote turn on, on the thing
Old Apr 27, 2007 | 11:15 AM
ttocs's Avatar
ttocs
yer getting free advise from the internet, be as complete and clear as possible and hopefully you will not be burned. The remote turn on is a wire that goes from the deck to the amp. When the deck it turned on it will put +12v on this wire, which tells the amp to turn on and take its power from the thick power wire. You need to get that wire up to the dash and then connect it to the blue/white that comes out of the deck. This is assuming(do you know what happens when you assume?) that you have replaced your factory deck with an aftermarket one but we do not know that............
ORIGINAL: eddiev22
alright i dont think i need to explain what i have done to my car to ask what wire to connect my remote turn on to, but i will
2 12' subs in a sealed box in the trunk, firing into the cabin, amp also in the trunk, remote turn on wire is already run to under the carpet at my pedals, but dont know what wire exactly to wire it to. i know seight has said the blue wire with the white/grayish stripe.. i know this.. but i cant seem to find the wire, i will go take a pic right now and post in minutes, but all im asking is what wire and where it is?
brb
Old Apr 27, 2007 | 06:57 PM
eddiev22's Avatar
eddiev22
ahhh sorry! still using my stock head unit, i used a high/low converter to my rear speakers
Old Apr 28, 2007 | 01:57 PM
eddiev22's Avatar
eddiev22
anyone??? what wire is it for a STOCK head unit! sorry never mentioned that before
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
