Amp won't turn on
Old May 8, 2007 | 10:09 AM
lonewolf06's Avatar
lonewolf06
Default Amp won't turn on
Hey i was reading some posts on the forums for help, and i came across one that said if RCA were used to hook up the headunit and amp it would be better well i have that and my amp was working perfectly till yesterday when it wouldn't turn on. I checked the fuse in the hood of the car and it is fine all other wires are fine. It is an audiobahn DUB8001 800W and the subs are 2 12' Kicker CompVr. If anyone knows whats wrong please reply thanks.
Old May 8, 2007 | 10:41 AM
ttocs's Avatar
ttocs
Default RE: Amp won't turn on
what kind of radio? if you have a voltmeter and know how to use it you first need to check for power at the amp connections.
Old May 9, 2007 | 09:41 AM
lonewolf06's Avatar
lonewolf06
its a pioneer. i asked a friend and he keeps sayin i blew a fuse, i checked them and there fine.
Old May 9, 2007 | 01:41 PM
ttocs's Avatar
ttocs
again we need to test for voltage at the amp connections. If you do not have a voltmeter you can get a testlight from an autoparts store for $10. We need to check for power at the power, ground and remote at the amp.
Old May 9, 2007 | 01:49 PM
PReal's Avatar
PReal
He speaks the truth, with no voltmeter or test light there is no way we can help you.
Old May 9, 2007 | 04:48 PM
ttocs's Avatar
ttocs
or check the fuse under the hood to start....
Old May 9, 2007 | 09:08 PM
str8wick3d's Avatar
str8wick3d
I know you said you checked your wires, but also check where your ground wire leads, If your ground wire is still on a painted frame, or has come loose, your amp will not turn on.
Old May 11, 2007 | 09:42 AM
lonewolf06's Avatar
lonewolf06
it ended up being what str8wick3d said it was my ground wire was loose, thanks for all of your help you guys very quick respones too thanks
Old May 11, 2007 | 10:18 AM
Ultimeas's Avatar
Ultimeas
Thats the exact problem that drove me nuts for days when I was installing my amp.
Grounding = important.
BOB ROME
Jul 26, 2023 01:54 PM
Thunderball
15
Nov 22, 2015 11:49 PM
logan409
Sep 26, 2015 07:43 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
