Putting sirius in 2007 GT
Old May 25, 2007 | 04:41 AM
blbrad's Avatar
blbrad
Default Putting sirius in 2007 GT
I just got a 2007 GT w/shaker 1000 and wanted to hook up the sirius receiver I already had. What's the best way to do it if I don't want to use the crappy FM modulator? I've read that the aux jack is only for ipods or devices designed for headphones, but would it work well connecting it to the line out on my sirius? Or is it better to take the time to put in something like a PIE adapter that is wired into the HU and connects to the receiver with a RCA-1/8' plug?
Old May 25, 2007 | 01:44 PM
knucklehead11's Avatar
knucklehead11
Default RE: Putting sirius in 2007 GT
I think your best bet is the PIE adapter from what I tried to read available...
Here's something I found that might work, not too sure though. You use RCA's as an input.
http://www.discountcarstereo.com/detail.aspx?ID=813
I think it uses the factory's CAN bus or RSE connector or something. There's three connectors on it. I'm not too knowledgeable about the shaker 1000 so I'm not sure if this is correct but it looks like it.
Old May 25, 2007 | 01:46 PM
ilmor's Avatar
ilmor
Did you not get the free 6 mo. Sirius service w/ your GT such as I did? The reciever is already satellite-ready, so why would you want the add-on thing? Just curious....
Old May 25, 2007 | 02:06 PM
blbrad's Avatar
blbrad
I just bought this one off the lot and didn't see anything about sirius on the sticker. I thought you needed a special HU, or is the shaker 1000 already sirius-ready?
I'm picking it up in an hour, so I haven't gotten a chance to play around with it yet.
Old May 25, 2007 | 02:58 PM
davisms's Avatar
davisms
Mine had Sirius all set up for me when I picked it up and it only had the Shaker 500. You should have the little bump on the trunk lid for the antenna.
The Sirius receiver is in the trunk on the passenger side and it plugs happily into the back of the Shaker.
Old May 26, 2007 | 12:36 AM
ilmor's Avatar
ilmor
ORIGINAL: davisms
Same deal for me.
Old May 26, 2007 | 03:30 AM
jets12's Avatar
jets12
ORIGINAL: blbrad
Yes, your shaker 1000 is sirius ready. check your trunk for the tuner. If you don't have a tuner you could use the sirius you already have, and yes you could use the line in. just need to find the right plug ins.
1996cobraconvertible
SVT Forums
13
Jan 7, 2016 04:50 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
9550
Oct 26, 2015 05:01 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Webster454
Sep 7, 2015 04:59 AM
