amp keeps blowin fuses
May 29, 2007 | 12:03 AM
Ok I have a 800w American Pro amp. It keeps blowin fuses. When ever i put a new fuse and connect the battery it blows. What the hells wrong?
May 29, 2007 | 12:13 AM
RE: amp keeps blowin fuses
If the fuse on the power wire that runs from the battery keeps blowing you have a short in your power wire.
If the fuse on the amp is blowing it could be a number of other things.
May 29, 2007 | 12:21 AM
Yea i forgot to mention that, its the fuse on amp.
May 29, 2007 | 01:33 PM
disconnect all the speakers and try again. If it blows again yer amp is toast, if it doesn't then check your speaker wires for shorts.
May 29, 2007 | 04:21 PM
I would also verify that you have the correct wires where they need to go. (Make sure power to power, and ground to ground)
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 3, 2015 08:43 PM
iamgobono
Sep 3, 2015 12:37 PM
