eclipse nav. probs. w/ shaker s197
Old Jun 19, 2007 | 08:16 AM
bomb79's Avatar
bomb79
Default eclipse nav. probs. w/ shaker s197
Ok i bought an eclipse avn 5435. figuring i could maybe install it.i called a shop and they told me 200 bucks to install i almost crapped so i said id get back to them later.anywho i havea friemd that works at audio pros i asked him and he told me if i have a the shaker system in my s197 i may have to re wire my entire car becuase the unit might not be compatible,has anyone esle experienced this.i would love as much feedback as possible.also if anyone has installed anavigation unit in there s197 i would love to know how you did it so i can attempt on my own.
thanks in advance
Old Jun 19, 2007 | 09:30 AM
NaplesBill's Avatar
NaplesBill
Default RE: eclipse nav. probs. w/ shaker s197
I just installed a Pioneer AVIC-D3 in my '06 GT. The install should be essentially the same. I have the Shaker 500. You will just need the correct harness adapter. I don't know about the Shaker 1000. There are two harness adapters you'll need to use. You can buy them as a set or as seperate pieces. They are made by Metra. The first one is used to connect your power, ground, battery and full range speakers. The second harness is used to connect the amp and subs. As I said, I just did this with a Shaker 500 so if you have a Shaker 1000 it may be different.
Old Jun 20, 2007 | 08:02 AM
bomb79's Avatar
bomb79
yes i do have a 500 i should have mentioned that. im surious as to where i need to splice and tap wires i heard i have to tap the VSS and so on . any help???
Old Jun 20, 2007 | 09:55 AM
NaplesBill's Avatar
NaplesBill
I didn't have to splice into any wires in the car. The Pioneer has a built in sensor that allows it to function without using the VSS connection. All the other connections were made through the use of the harness adapters. This is what you need:
Metra Harness Adapter
That link shows the kit on backorder but it also lists the individual parts. There are actually two harnesses you need. Once you have these I can help you rewire the amp harness adapter to work in your car. You have to move a couple of the pins around. There is also a need to reduce the voltage on the amp turn on lead from your aftermarket radio. I'm going to get that info and complete it on my car today. I'll keep you posted on the necessary steps. It will work without this but the speakers will pop when you turn the car on/off.
Old Jun 21, 2007 | 08:17 AM
bomb79's Avatar
bomb79
wow this seems alot more complicated than what i was hoping for.i guess 200 bucks to install isnt as bad as i thought...but ill love as much info as you can give me.
Old Jun 21, 2007 | 08:25 AM
NaplesBill's Avatar
NaplesBill
It's not really complicated at all. You buy the dash kit, harnesses and then just crimp and plug everything together. It's actually very easy.
RdRang95
Apr 12, 2011 07:03 PM
redrocker66
Jan 24, 2010 08:41 PM
davisms
May 6, 2007 02:26 AM
Redleg
Dec 8, 2006 03:09 AM
Cambria
Sep 25, 2005 09:15 PM
