Mustang power window module help!
Old Jun 30, 2007 | 09:25 PM
/\CHRIS/\'s Avatar
/\CHRIS/\
Default Mustang power window module help!
Hi
I have a 2001 Ford Mustang Gt that I hooked up a pyle alarm up to. I bought a "Smart" Window module. It is supposed to roll both windows up and down. I am wanting to know how I should wire this thing up. Will I need any diodes or relays or anything like that?
Black/white-(Cut loop for 2 window up/down mode)
Green/Black=Front right motor down
Green= Front right switch down
Red= Fused 12v constant
Blue/black= front left motor down
blue=front left switch down
black=ground
brown/blue= front right motor up
brown= front right switch up
yellow= (-) up activation input
yellow/white=(-) down activation input
white/blue= front left motor up
white=front left switch up
Old Jun 30, 2007 | 09:26 PM
/\CHRIS/\'s Avatar
/\CHRIS/\
Default RE: Mustang power window module help!
Well I haven't got this module to work right. The only window I have gotten to go down is the passenger side and it was accidentally left unplugged. Both sides wont go up and both wont godown with the switches plugged in.The module is also getting warm and making a humming noise which cant be a good sign. Could I please have some help. I have all the wires that are supposed to be ran to the motors like 2 inches from both motors and the same goes for the switches also.
Here is how I have it wired
Window module Car window wires
Pass side motor down- Green/black to the Red wire on motor
Pass side motor up- Brown/Blue to Yellow wire on motor
Pass side switch up- Brown to White/Yellow
Pass side switch down- Green to Tan/Light blue
Drivers motor down- Blue/Black to Yellow on motor
Drivers motor up- White/blue to Red on motor
Drivers switch down- Blue to Yellow
Drivers switch up- White to White/black
Then of course the 12v power, ground, and I cut the loop.
Can someone please help me out?
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
drumhedd2005
Aug 13, 2015 09:59 AM
daytooday
Aug 11, 2015 09:22 AM
