S-197 Help w/ AVIC-D3
Is the vehicle speed wire going to the back of the stock radio a different signal than the VSS wire from the PCM? I am connecting a f series nav unit.
ANSWERS TO COMMON QUESTIONS WHEN INSTALLING:
Shaker 500/1000 Subwoofer Popping during turn-on:
popping is due to the fact that most factory Ford stereos only send a 5 volt turn on signal to the sub amp.
All aftermarket radios have 12 volt remote outputs.
To avoid the pop, you will need to add a 12 volt to 5 volt regulator in line on the remote lead.
It can be purchased at any Radio Shack, the part number is 276-1770.
Do you think using a smaller gauge wire will adversely effect it? I thought about using an old audio connector for a desktop. the wires in that (the pins line up great) I believe are 28AWG and rated for 300V and 80*C. I think it should work fine but jsut want to double check
Good job man…,it’s really such a nice post and knowledgeable too. It helped me a lot. keep it up
shimanoreels
shimanoreels
