wiring system
Old Aug 14, 2007 | 09:23 PM
joeybutts's Avatar
joeybutts
Default wiring system
hey guys, curious as to how i am going to wire my new setup. I have 2 amps now (one for subs and one for comps) so i need a distributor block, is there anything else i should get? I believe my power wire is 4 gauge coming off the battery. Thanks!
Old Aug 15, 2007 | 02:45 PM
ltrayne84's Avatar
ltrayne84
Default RE: wiring system
capacitor and depending on how many amps you think you're gonna be putting out, a thicker power wire with a ground wire being the same thickness
Old Aug 15, 2007 | 04:38 PM
PReal's Avatar
PReal
ORIGINAL: ltrayne84
Capacitors are a hugegantic waste of money and installation time.
You will need to run 4 gauge off the battery and split it into dual 8 guage at a dbock as close as possible to the amps.
Also, make sure that you use the same gauge wire as a ground as you have power wire feeding your amp.
PReal's Avatar
PReal
BTW, I always like to get a fused dblock. It is one more level of protection.
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
Sep 24, 2015 09:18 PM
cbird1177711
Sep 3, 2015 08:43 PM
