Custom Trunk Finished!
Old Aug 17, 2007 | 05:42 PM
  #21
aCiD's Avatar
aCiD
Default RE: Custom Trunk Finished!
ORIGINAL: laserred38
Why did you cover 1/5th of the subs with the false floor? [&:]
Thank you, I`ve honestly been waiting for this question since I posted.
I left the Mach460 resonating chamber in the rear for my rear 6.5s, so the maximum height I could make the box is 11``, so 11`` off the floor leaves the subs at that height, function over form.
Re: Trunk space, the only stuff I keep in my trunk (or use it for in general) is a little quick detailer and a duster, now they`re hidden in a secret compartment behind my rear seats.
Old Aug 18, 2007 | 03:34 AM
  #22
laserred38's Avatar
laserred38
I see. I think I would have mounted an amp on each side then. Like one behind each tailight on the walls of the trunk. In custom panels of course, so that the trunk would be squared off. Nice work though.
Old Aug 18, 2007 | 02:12 PM
  #23
ScottXL's Avatar
ScottXL
How'd you take the picture of your front wheel going?
Old Aug 18, 2007 | 03:16 PM
  #24
aCiD's Avatar
aCiD
ORIGINAL: ScottXL
I`ll make a seperate post about that later, I have much better pics like that.
Old Aug 19, 2007 | 03:47 AM
  #25
ttocs's Avatar
ttocs
see, and I bought my stang because of that HUGE trunk....................
Old Aug 19, 2007 | 10:00 PM
  #26
ScottXL's Avatar
ScottXL
ORIGINAL: aCiD
ORIGINAL: ScottXL
Good, 'cause those pictures are sooo awesome. ^-^
Old Aug 20, 2007 | 12:19 PM
  #27
ttocs's Avatar
ttocs
"resonating chamber"??????????
ORIGINAL: aCiD
Old Aug 20, 2007 | 08:26 PM
  #28
aCiD's Avatar
aCiD
ORIGINAL: ttocs
ORIGINAL: aCiD
That big composite plastic box under the rear deck that houses the stock 5x7s and tweeters.
Note: I`m still working on the post about those pics, I just moved so I`m very busy right now.
Old Aug 20, 2007 | 10:49 PM
  #29
ttocs's Avatar
ttocs
ok I figured that was a fancy name for a box but wanted to make sure. I would not have designed my trunk and system around that rubbermade pos myself... It is not worth that much trouble and would have given you the space you needed.
Old Aug 20, 2007 | 11:31 PM
  #30
aCiD's Avatar
aCiD
ORIGINAL: ttocs
True, I won`t deny that that may be on my regrets list, but what`s done is done for now.
