Custom Trunk Finished!
Old Aug 21, 2007 | 09:53 AM
  #31
califas_1987's Avatar
califas_1987
Default RE: Custom Trunk Finished!
Actually, you have more trunk space than my stock 02 GT Convertible with the Mach 1000
++Plus Much Better Sound
Old Aug 21, 2007 | 05:40 PM
  #32
aCiD's Avatar
aCiD
ORIGINAL: califas_1987
I`ve always wanted to see the Mach 1000 system in person, the pictures I`ve seen look crazy.
Old Aug 21, 2007 | 06:19 PM
  #33
seight311's Avatar
seight311
I've never heard of Macrom comps.
Me too!
Would like to hear some now though.
I like the design man, very clean, simple and functional, good to see it's easily removable for the track.
Only thing I dont like is the massive Honda emblem you have for an amp rack
Old Aug 21, 2007 | 06:22 PM
  #34
aCiD's Avatar
aCiD
ORIGINAL: seight311
Me too!
Thanks, definitely try to get an oppurtunity to hear some, you won't be dissappointed.
Awww come on, now that's all I'm going to think of when I see it from now on!
Old Aug 21, 2007 | 09:45 PM
  #35
seight311's Avatar
seight311
I know thats why I pointed it out. It's one of those hidden subliminal type things. Just be grateful it's just a H and not a bowtie, how pissed would you be if the design you ended up with was a bowtie? [:'(]
Old Aug 24, 2007 | 01:44 PM
  #36
stangant's Avatar
stangant
how did u attach the trunk lid cover? is it removable cuz im making 1 now and i want a good way to attach it.
Old Aug 24, 2007 | 02:17 PM
  #37
aCiD's Avatar
aCiD
ORIGINAL: stangant
Excellent question, to which I have a terrible answer. I will put down as another regret the means I used to attach my cover. Industrial adhesive... like the metal will come off before the adhesive releases. I fell back on this cause I couldn't find another means that would be strong and completely resistant to vibrations. It's probably the best solution if you never want to remove it, but if you do, it's certainly the worst option.
Commercially available trunk lid covers use (one time use) plastic clips. So you'd have to get a new set of clips everytime you remove it, and they would not be nearly as resistant to vibration.
Old Aug 24, 2007 | 08:26 PM
  #38
stangant's Avatar
stangant
i was thinkin i would use some of the heavy duty velcro that might hold it there.
Old Aug 24, 2007 | 09:12 PM
  #39
bigtinybob's Avatar
bigtinybob
looks good.how heavy is all of that
Old Aug 24, 2007 | 11:29 PM
  #40
aCiD's Avatar
aCiD
ORIGINAL: stangant
The problem is the surface on the trunk you'd be mounting to is farrrrr from a perfect plane, so it would be nearly impossible to use velcro, I had to add 3/4" spacers in order to use the industrial adhesive in the centre area.
