need to wire 2 amps
Old Aug 20, 2007 | 11:35 PM
mike68's Avatar
mike68
Default need to wire 2 amps
got 2 amps one for a solo baric l7 15 and another for 2 sony xplods. i need to know how to wire the amps because only my solobaric is working but the power light on the xplod amp is on but they wont play some one help me out please
Old Aug 20, 2007 | 11:45 PM
jakeachy's Avatar
jakeachy
Default RE: need to wire 2 amps
are your RCA cables connected properly? do you have a solid ground? is your remote wire good? speakers connected properly?
Old Aug 21, 2007 | 12:54 PM
ttocs's Avatar
ttocs
"strapping" two amps together for one sub is a big deal and only a couple of amps out there can support it.
Old Aug 21, 2007 | 05:06 PM
PReal's Avatar
PReal
It sounds to me like you are running 2 amps to two different sets of subs. This is a very poor idea. It will sound like poo, have cancellation problems, and look completely ghetto. Don't do it...
If you are using one amp to power the sub and another amp to power front speakers you will simply need to make sure you have two sets of RCA's, a distribution block, and smaller wire after the dist block to the amps.
If you have 8 gauge right now, you will need to upgrade the main power wire from the battery to 2 or 4 gauge, but then you can use the existing 8 gauge to run from the distrobution block to the two amps. Everyone from wal mart to your local audio store will have d blocks.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
