what amp alt should i get?
Old Aug 28, 2007 | 07:21 PM
GIJOE's Avatar
GIJOE
Default what amp alt should i get?
[align=left]Can someone please tell me what alt i should get, the alt i have keeps on screaching so im thinking that maybe it just dosent have enough amps. I do have a mach 1000 adio system so i wonder if thats why
[/align][align=left] [/align]
Old Aug 28, 2007 | 08:50 PM
contentsunderpressur's Avatar
Default RE: what amp alt should i get?
Go with a stock ford alternator. It puts out 14.5 volts. An aftermarket alternator from a parts house is usually in the 13s. The stock alternator will work just fine for the mach system.
Old Aug 29, 2007 | 01:22 AM
kura's Avatar
kura
Your alternator is screaching? Interesting. Are you having any issues with your voltage dipping when the car is running and the mach bumping? Or starting issues because of a dead battery?
Personally I wouldn't want to spend the money on an alternator unless it wasn't doing it's job. I could think of tons of things I would rather spend the money on. But if you really insist on it, you can get them rebuilt for higher amperage for fairly cheap rather than buying a new one.
Old Aug 29, 2007 | 08:01 AM
PReal's Avatar
PReal
Your stock audio system is causing no ill effects to your alt.
It could be a bad bearing, bad brushes, who knows, but I would replace the alt.
Old Aug 29, 2007 | 08:25 PM
seight311's Avatar
seight311
300 amp for sure
145-165 is fine
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
