shaker 500 adding amp and sub help.
Old Aug 30, 2007 | 06:39 PM
str8wick3d's Avatar
str8wick3d
Default shaker 500 adding amp and sub help.
How could I get the remote wire to turn on? I could tap into a stock amp right?
Old Aug 30, 2007 | 07:43 PM
silver2006's Avatar
silver2006
Default RE: shaker 500 adding amp and sub help.
the stock amps only have 5volts to turn them on. you need to find a 12volt switched lead to turn on after marketamps. check the fuse panel the radio fuse should work for what you need. just tap off it.
Old Aug 30, 2007 | 08:38 PM
jakeachy's Avatar
jakeachy
ORIGINAL: silver2006
if you are adding another amp and sub, you would want to get another deck. ive done this atleast 10 times: install your aftermarket unit. splice your remote turn on into 2 wires. one wire will be 12v already, use that for your new amp. on the other remote wire, take a resistor and fuse and wire them into that wire. anything from 5-10v will be fine. 12v is too risky for failure or short life, so i strongly suggest a resistor and wire. if you do take the lead from the fuse box, you will have unconstant current going to your amp. that is NOT good.
Thunderball
15
Nov 22, 2015 11:49 PM
Oct 5, 2015 07:40 AM
breaking
Oct 2, 2015 01:27 PM
mustangheaven
Sep 29, 2015 11:00 AM
mungodrums
Sep 28, 2015 10:54 PM
