ground
Old Oct 6, 2007 | 05:59 PM
Berry94's Avatar
Berry94
Default ground
wheres the best place to ground the amp to, icant find a spot in the back any one have an idea?
Old Oct 6, 2007 | 07:01 PM
seight311's Avatar
seight311
Default RE: ground
A solid flat place of metal, take a razor or some sandpaper and make sure you have a clean, bare metal spot, take some self tapping screws and drill them in.
Theres a video tutorial on properly grounding an amp. Go to my FAQ Sticky, and go down to where it talks about general tutorial videos.
Old Oct 6, 2007 | 09:24 PM
jakeachy's Avatar
jakeachy
Default RE: ground
i use a nice dab of silicone before screwing.
Old Oct 7, 2007 | 09:39 PM
ttocs's Avatar
ttocs
Default RE: ground
before screwing? maybe after.....
Where is the amp being mounted? The gas tank goes under the spare tire well in most stangs and there really isn't much space under there.
Old Oct 7, 2007 | 09:43 PM
jakeachy's Avatar
jakeachy
Default RE: ground
ORIGINAL: ttocs
a nice amount on the ring terminal before being screwed to the ground spot will make the silicone smush out surrounding and covering the hardware.
after would just cover all of it, and be a messy goop. ive done both ways before, you dont need to act superior to me.
Old Oct 7, 2007 | 11:35 PM
stangant's Avatar
stangant
Default RE: ground
i know on a 2000 v6 model there is a ground that you can use if you remove the left trunk panel. It is a ground for sumething else so all you will have to do is unscrew place the ground wire then screw back in not hard and no drilling required.
Old Oct 8, 2007 | 05:31 AM
joeybutts's Avatar
joeybutts
Default RE: ground
ORIGINAL: jakeachy
ORIGINAL: ttocs
I would think that the silicone would form a small barrier between the terminal and the ground spot, because the likely hood of getting all the silicone out would be minimal. I think that is what ttocs is thinking. The point of the ground is to have nothing there but metal to metal, isn't it?
In the vert, i used the mount for the amp till i broke the bolt off, then i used what i believe to be the ground for the convertible top motor.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
Mr. D
Suspension
Sep 20, 2015 09:20 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
