4 gauge wire to nine 2 connection quick ?
Old Oct 10, 2007 | 07:38 PM
Emanpimpster's Avatar
Emanpimpster
Default 4 gauge wire to nine 2 connection quick ?
Ok i installed my nine.2 amp and everything sounds pretty good if you ask me. My "problem" is that i had to cut about 1/2 of the 4 gauge wire to make it fit into its hole on the amp. I think i should have made my amp rack a little differant because its kind offorcing the ground and power cablesto make a sharp angle and im worried about my cables, since they are have the thickness as usual and at a funny angle, pulling out or the little strands of wire breaking. Would there be any crimp on spade style connectors that i can crimp onto the cable and just hook the other end up to the amp? like this maybe??
http://cgi.ebay.com/ws/eBayISAPI.dll...=tab%3DBidding
Old Oct 10, 2007 | 08:30 PM
jakeachy's Avatar
jakeachy
Default RE: 4 gauge wire to nine 2 connection quick ?
if you go that route then use solder.
Old Oct 10, 2007 | 09:20 PM
Emanpimpster
solder the wire to the spade connector?
Old Oct 10, 2007 | 09:26 PM
jakeachy's Avatar
jakeachy
yeah. crimps suck, especially in your situation
Old Oct 10, 2007 | 09:44 PM
Emanpimpster
you think my plan would work though?
Old Oct 10, 2007 | 09:46 PM
seight311's Avatar
seight311
Crimp and solder...
When your wire is too large to fit into the amp input, either...
A. Get a connector
B. Trim as absolute minimal as possible (as in the actual wire strands) and pinch as best you can with your fingers and give it a slight twist to compact everything as best possible. Slide it in the terminal slow and strait to make sure the individual wires don't stray away and possibly leave one a short distance to a ground or remote input you may see a few jumping sparks.
Old Oct 11, 2007 | 08:13 PM
ttocs's Avatar
ttocs
what does the connection look like? Is it a screw type that you put a spade or a ring under or is it where you can stick the entire wire in it and then tighten it down? I founda couple of alpine 4 to 8 awg reducers the may work for your application.
Old Oct 11, 2007 | 09:45 PM
Emanpimpster
the terminal on the amp is a little plastic box with a gold screw on top that tightens down a clamp onto the wires would these reducers help?
Old Oct 11, 2007 | 11:28 PM
jakeachy's Avatar
jakeachy
ORIGINAL: Emanpimpster
no, from what i visualize you want to do what myself/seight reccommended.
Old Oct 12, 2007 | 09:57 AM
ttocs's Avatar
ttocs
you are really not gaining anything from running 5 awg to the amp, it is not designed for it. If that wire does come loose you will have some sparks on your hand before the fuse pops up front. I would consider a distrobution block and split it down to 8 awg.
SteelerNation82
Sep 16, 2015 07:11 AM
unit91
Sep 15, 2015 09:53 AM
rksnow1
Sep 14, 2015 08:46 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
