Head Unit 08 Gt
Old Oct 17, 2007 | 05:13 PM
dethtrap's Avatar
dethtrap
Default Head Unit 08 Gt
Hey guys I am looking into installing an avic-d3 in my 08 GT i just picked up on saturday. I have a few questions.
1. How do you remove teh stock head unit.
2. Are there step by step instructions anywhere that I can use.
3. I have Sirius satelite already is this going to cause a problem?
4. Anything else that you can think of that I may not be thinking of
Thanks Guys
Old Oct 18, 2007 | 08:32 AM
BigFloppy's Avatar
BigFloppy
Default RE: Head Unit 08 Gt
https://mustangforums.com/m_3581800/tm.htm
Old Oct 18, 2007 | 02:05 PM
dethtrap's Avatar
dethtrap
yea i read that post before posting this it didnt really have the information i was looking for but it did have some good stuff that i didnt think about
Old Oct 19, 2007 | 07:53 AM
JMaN05's Avatar
JMaN05
buy a ford head unit puller. you can get knock off ones at most wal-marts. they do the job
Old Oct 19, 2007 | 08:06 PM
SatinSilverStang's Avatar
SatinSilverStang
man, i just had mine apart today adding some stuff, you need to remove the center counsle first, its two philips head screws all the way in the back of the center compartment. then you remove the two side panels, they just pop off with a lil pull. then onto i believe 6, 8mm or 9mm bolts to remove the venter panel, you'll need to disconnect all the harnesses behind there. by now the only thing left should be four more of the same types of screws holding the radio in, then out she comes.
Old Oct 22, 2007 | 04:03 PM
bluestang35's Avatar
bluestang35
dethtrap
You cannot use your factory sirius with aftermarket units. You will need a new sirius tuner for the pioneer unit. you factory sirius is located in the trunk passenger side wall.
You can use the factory antenna but you have to locate new sirius unit in trunk area.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 30, 2015 03:48 AM
