Power Wire Into Amp ( Pic Please )
Old Oct 23, 2007 | 08:17 PM
Pelley_Pony's Avatar
Pelley_Pony
Default Power Wire Into Amp ( Pic Please )
Getting ready for a system install and wondering if anyone can help me with a picture of where the power wire goes into the Amplifier. I have my power wire and RCA cables ran to the trunk allready. I bought a alpine amp, Can any size power wire go into it or is it strictly one size.
I have a 4 gauge stinger wire, Will this work in a Alpine V Power amp?
Thanks
Old Oct 23, 2007 | 08:41 PM
Emanpimpster's Avatar
Emanpimpster
Default RE: Power Wire Into Amp ( Pic Please )
you might have to trim some of the wire to make it fit. It should say with slot is for power right on the amp
Old Oct 23, 2007 | 11:28 PM
MU71L4710N's Avatar
MU71L4710N
as long as the wire goes in and you can tighten it its fine. you dont need to be running a 2000+watt amp off 8 guage wire though, and you might not necessarily need 2 guage for a 500watt amp.
+1 it will say on the amp which one is the remote (which will be the smallest slot), ground, and power. if not then you can try taking the top cover off most of the circuit boards will have power ground and remote labels on them (will probably say gnd for ground, remote will be the smallest one, and the odd ball will be power)
Old Oct 24, 2007 | 12:20 AM
seight311's Avatar
seight311
If you have stock wiring in the rest of your electrical system, you could probably get away with 8 ga. Thats pretty much the biggest the rest of your electrical system is anyway. Nothing wrong with just running 4 ga. to be safe. You don't need to really worry much though until you upgrade the other stuff.
Old Oct 24, 2007 | 02:47 PM
jakeachy's Avatar
jakeachy
ORIGINAL: MU71L4710N
I would use 2-4 gauge for any amp. Its just a neccessary precaution.
I have seen 8 guage melt on a 200w amp, anything can and will happen.
Old Oct 24, 2007 | 07:32 PM
seight311's Avatar
seight311
Due to a bad install maybe, you would have to be running some insane power to just flat out melt a power wire.
Old Oct 24, 2007 | 07:59 PM
Pelley_Pony
I have the 4 gauge wire allready ran into the trunk so its no problem using that. The amp should be here next week, If i have any questions i will be back.
First install so their might be a few questions
Old Oct 24, 2007 | 08:46 PM
06z28eater's Avatar
06z28eater
good luck with it man, nice color also lol
Old Oct 25, 2007 | 05:26 AM
Pelley_Pony
ORIGINAL: 03z28eater
Goes to primer in 2 weeks just before storage, Cant wait to get rid of that ugly color
Old Oct 25, 2007 | 09:51 AM
truckstoy's Avatar
truckstoy
looking at the Alpine amps it looks like they will accept the 4g wire just remove the neg - wire off the batt and remove the fuse on in line holder wire up the amp then you can reconnect the fuze & batt wire.
