cant hear crap from sub =(
Old Oct 31, 2007 | 09:21 PM
Eduardo's Avatar
Eduardo
Default cant hear crap from sub =(
I just recently bought an 04 Gt with the mach 460. First thing I did was put an aftermarket stereo in it (JVC KD-AVX33). I just finished install my amp and sub but I cant hear anything from my sub. Same thing happened with my 97 gt only I fixed it using another device that was uncomfortable and dont want to have to buy another. I hooked up the line out RCA's to the RCA that goes to the amp. I tried everysingle line out on that harness and nothing happened. Did I set it up wrong or what!?! Remote, power, and ground are all fine. Just that the amp isnt getting an audio signal. Need some advice on hooking it up or do I have to buy another amp.
link to amp: http://shop1.outpost.com/product/475...H:MAIN_RSLT_PG
link to headunit:http://www.crutchfield.com/App/Produ...=448&avf=N
link to sub:http://www.crutchfield.com/App/Produ...c=3&tp=111
Old Oct 31, 2007 | 09:46 PM
stangant's Avatar
stangant
Default RE: cant hear crap from sub =(
is the amp turning on? there might be a bad conection or the headunit is just bad, it could happen.
Old Oct 31, 2007 | 09:58 PM
MU71L4710N's Avatar
MU71L4710N
check to see if the amp is turning on (power light, fan, anything). maybe dumb question but you hooked the remote line up right?
if the amp isnt turning on try getting like 1 foot of speaker wire, strip both ends (all 4 wires) and stick 1 end of each wire in the remote line and the 12v power line. then bridge the 2 remaining strands (basically your just attaching the 12v power line to the remote turn on). my last head unit something screwed up and the remote line was no longer throwing out any power so my amp wouldnt turn on. i temporarily wired a switch todo as i explained above until i found a decent power line that came on with the cars power to use instead of the remote from the deck.
Old Oct 31, 2007 | 10:12 PM
oxfordgt's Avatar
oxfordgt
Take it all out, sell it and buy some power parts.
Old Nov 1, 2007 | 12:09 AM
Brute03's Avatar
Brute03
are you sure you don't have the patch cables running to the 'output' side of the amp instead on the 'input'?
Old Nov 1, 2007 | 11:42 AM
joeybutts's Avatar
joeybutts
pics of install would really help.
jerrytubes
Oct 23, 2015 12:11 PM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
