Head Unit troubles
Old Nov 4, 2007 | 11:28 PM
Jon2887's Avatar
Jon2887
Default Head Unit troubles
Hey guys i have an 84 mustang gt vert and i decided to finally get a head unit for it ( there was none in it when i bought it from a private owner, i mean nothing was there). So i buy the wiring adapter also but i cant figure out which plug to put the adapter into, the one i plug the harness and head unit into i get no sound. Are there any diagrams for my cars wiring or does anyone have any ideas whats up?
Old Nov 8, 2007 | 10:37 PM
UK PONY's Avatar
UK PONY
Default RE: Head Unit troubles
I'm having a similar issue putting a replacement head unit into my '90. The problem as I see it is that there is just one, common, earth for all the speakers & the aftermarket adapters always assume seperate earths - it should just be a case of grouping all the earth leads together on the adapter side & bridging over to the main harness speaker earth lead.
To see if you're plugging into the correct factory plug (assuming you're seeing 2) grab a multimeter & see which plug is carrying 12 volts when the ignition is on or at the accesory position. That way you'll know which plug is power & which is for the speakers.
Old Nov 9, 2007 | 09:40 AM
ttocs's Avatar
ttocs
Your car probaly has a common ground wiring system in it. Does the speaker hrns have 5, or 8 wires on it? You should be lucky that the factory radio is not still in there as it is a pita to get out.......
ORIGINAL: Jon2887
Old Nov 9, 2007 | 09:41 AM
ttocs's Avatar
ttocs
You may have a premium system, is there an amp under the seat or under the radio? Either way your car should not be a problem. Once we know if there is a premiums sytem in the car there is only a couple of things to do........
ORIGINAL: UK PONY
Old Nov 11, 2007 | 12:18 AM
UK PONY's Avatar
UK PONY
ORIGINAL: ttocs
From looking at the other options the car has I believe it has the premium system - haven't seen an amp but then again I wasn't looking for one either.
What are the couple of things to do?
Thanks in advance for the help.
Old Nov 11, 2007 | 06:11 PM
ttocs's Avatar
ttocs
dude start a new post and be complete in all your equipmentand ask all the questions you want to know answers to. I am not going to pick and paste to answer your questions between 3 other peoples posts. It is hard for me to keep on who is on first and rude to the person that started this post[&:].
CS2007
Jun 25, 2019 09:45 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
ChampInSD
Oct 2, 2015 04:55 AM
