Old Oct 20, 2015, 11:13 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
replacing my entire mach 460 system
Old Nov 28, 2007 | 05:16 PM
SilverBullet09's Avatar
SilverBullet09
Default RE: replacing my entire mach 460 system
alright well for subwoofers i think im going to get two eD 9kv.2s and power them with a NINe.2 amp. for speakers i think that im gonnause four focal 570 CA1s (2 in the doors and 2 in the rear). does that sound like a good setup? what amp or amps should i use to power the speakers? also do you think i should replace the mach tweets? if so, what with?
Old Nov 28, 2007 | 05:18 PM
PReal's Avatar
PReal
I still can't get around to using an ipod in the car even though between the wife and I we have 3.
X2 on clean power. When having a ton of extra power, properly adjusting your amp will give you plenty of headroom to make changes and see how it effects sound quality.
Old Nov 28, 2007 | 05:45 PM
KSUWildcatFan's Avatar
KSUWildcatFan
I'd save your money on putting speakers in the rear. Don't bother.
Take the money you'd spend on the rear speakers and put it toward a really solid amp for the front speakers. I'm not familiar with Focal stuff (other than that I know it's high quality), but you should be able to slap a nice amp on them and be fine. How much power does the NINe.2 put out at the impedence of your components? Maybe consider buying two?
You have high-dollar taste. That's good, though. ;P
-Jordan
Old Nov 28, 2007 | 05:53 PM
SilverBullet09
umm...im not positive but im pretty sure the NINe.2 puts out 2x200 at 2ohms. someone correct me if im wrong.
KSUWildcatFan
If that's true, then that'd be just grand for your front stage. Headroom FTW!
-Jordan
Old Nov 28, 2007 | 05:55 PM
KSUWildcatFan
http://ampguts.realmofexcursion.com/...esigns_NINe.2/
150x2 @ 2ohms
I decided I'd stop being lazy and loaded up Ampguts. :P
Ampguts is your friend..
-Jordan
Old Nov 26, 2022 | 12:48 AM
diddles113's Avatar
diddles113
Sorry i really dont know what im doing but if I were to just wire a new head unit to the same factory wires and get a new amp that also wired into the factory wires and new speakers same thing... Would that work? Any suggestions for amps if so? Also can I just bypass the amp if I get a new head unit. The wires would then run straight from the head unit to the speakers right?
Granatelli Sales
Jan 20, 2020 12:34 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
iamgobono
Sep 3, 2015 12:37 PM
cbird1177711
Sep 2, 2015 08:51 PM
