mach 460 and adding subs
Old Mar 10, 2005 | 02:00 PM
BewareOfBite's Avatar
BewareOfBite
Default mach 460 and adding subs
anyone one know how to wire another amp to the mach 460 sound system? i want more bass in my system
Old Mar 10, 2005 | 02:37 PM
rednblackdawg's Avatar
rednblackdawg
Default RE: mach 460 and adding subs
I think it will be hard to do. I know you cant install an amplifier onto an already amplified signal. If you can tap into the speaker wires before the amp, it may work. Have you considerd going with an aftermarket unit and a wiring harness for your car. That way you could hook the mach system up and add an amp and sub to the RCA outs of the aftermarket system.
Old Mar 10, 2005 | 03:12 PM
Red 5's Avatar
Red 5
Check this out.
http://cobramods.com/subwoofer_setup_to.htm
Old Mar 23, 2005 | 09:49 PM
wicked04's Avatar
wicked04
check out this link. it explains it all.[URL=http://www.mustangworld.com/ourpics/fcar/despeeds1.htm]
Old Mar 26, 2005 | 01:00 AM
BewareOfBite
Do u know if when u hook it up like that that the mach amps are still hooked up to? or is it either the mach ones or the after market amp?
Old Mar 26, 2005 | 01:43 AM
dc_mann8's Avatar
dc_mann8
i would suggest just getting an aftermarket head unit and amp...imo
Old Mar 26, 2005 | 12:07 PM
wicked04's Avatar
wicked04
i hooked mine up this way using the line out converter. the data cable that you use is before the stock amps, so you're bypassing them. i hooked a rockford fosgate 300 watt amp and bridged it to a 12 in a small sealed box. sounds awsome. i really like the stock system in my car and wanted to keep it. this worked out really well.
Old Mar 26, 2005 | 05:17 PM
Jimmz's Avatar
Jimmz
Yeah its a pain in the a**! If i were you i'd just replace your amps with one big one. Then you can run the one amp through your whole system. Get a 4 channel and then run it to your components and subs. But if you dont want subs get a 2 channel. But since you want bass im assuming you want subs, so go with a big 4 channel, that way instead of adding another amp and having like 4 amps you'll have one big one, with more power
Old Mar 27, 2005 | 04:04 PM
SilverStallion's Avatar
SilverStallion
If you have an aftermarket headunit it probably has pre-amp outputs on the back, which you can run right to an amp for subs...if thats what you mean. The stock 460 amps will run the speakers, and the new amp will run the subs. That's probably the easiest way.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Oct 5, 2015 07:40 AM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
