loud crack noise with head unit
Old Dec 4, 2007 | 01:16 PM
cobra4life_006's Avatar
cobra4life_006
Default loud crack noise with head unit
I have a 2000 mustang with a mach 460 sound system. I put an aftermarket pioneer head deck in with an aftermarket amp and subwoofers. I now have a loud crack when I turn the head unit on (like a powersurge from the factory amps kicking on late). I was able to get rid of the sound by connecting the factory amp turn on wire with the all time 12+ wire, but obviously that drained my battery and that is no good. All of the factory speakers work great along with the amp and subwoofers after the crack that happens when the head deck turns on. I want to know if anybody knows how to get rid of this sound. I would appreciate the input guys.
Old Dec 4, 2007 | 01:20 PM
Dave5point0's Avatar
Dave5point0
Default RE: loud crack noise with head unit
You need to put a 1000 ohm resister in line with the remote turn on wire for the factory amp. It will stop that annoying thump, definitly take that wire off of the constant, its not good for the amp to do that, go back to the blue/white or just blue on some h/u. In the long run you really should bypass the stock amp and do aftermarket speakers, but as long as it works now just go with it i guess.
Old Dec 4, 2007 | 01:31 PM
seight311's Avatar
seight311
FAQ sticky has info on this matter as well.
Old Dec 4, 2007 | 01:56 PM
cobra4life_006
Thanks for the input. I will try the resistor out and see how that goes. thanks
Old Dec 10, 2007 | 02:31 AM
Military_man_88's Avatar
Military_man_88
I have aftermarket everything and it does that to mine to..(not trying to hijack). Should I do the same thing?
Old Dec 10, 2007 | 10:51 AM
Dave5point0
ORIGINAL: Military_man_88
nope, i only do this with aftermarket headunit to factory amp/speakers
you've got issues it sounds like if you have aftermarket everything
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
