Car Audio question
Old Dec 5, 2007 | 07:38 PM
sportstar91's Avatar
sportstar91
Default Car Audio question
i am buying a sony xplode 10" sub and a kicker 600 watt amp. i have the stock radio in my car and i dont really want to buy a new one. i know i need to buy this -> http://www.sjgreatdeals.com/sisloc80.html
a line out converter but do i need to buy a toggle switch to turn the amp off. i have seen some guides need these and others dont.
p.s.
my car is a 2002 v6 mustang
mach stereo system
edit:
nvm i guess i can wire into ignition to set amp to turn on and off when the ignition is turned
Old Dec 5, 2007 | 08:38 PM
seight311's Avatar
seight311
Default RE: Car Audio question
When they say Xplode, they mean it.
Old Dec 5, 2007 | 11:39 PM
ttocs's Avatar
ttocs
the kicker amp more then likely has a high level input section built into it. I would try it and see if there is noise before going with an loc.
All you need for the remote turn on is a +12v switched wire that can be found at the fusebox or behind the radio. You do not want a switch unless you want to add one, it is a super "custom" install to some people...
Old Dec 6, 2007 | 04:04 PM
Dave5point0's Avatar
Dave5point0
lol
Old Dec 6, 2007 | 07:55 PM
sportstar91
ORIGINAL: ttocs
thanks, already bought the loc...lol oh well
it was only like 15 bucks.
Old Dec 7, 2007 | 02:26 AM
seight311's Avatar
seight311
If yout alking about the sub being $15, you could have had a much better 12" for $13. Smoke that Sony day in and day out, not to mention with a 5 year warranty.
Old Dec 7, 2007 | 07:12 AM
sportstar91
no the loc...but also
how to i hook the subs into the sterio if i dont use the loc.
my stock sterio does not have to right hook ups
Old Dec 7, 2007 | 01:26 PM
seight311's Avatar
seight311
You don't, well you can't actually.
LOC or you need an amplifier and your head unit needs rca pre-outs.
Old Dec 7, 2007 | 03:56 PM
ttocs's Avatar
ttocs
look on the amp and see if there is an input section labelled "high level input"
Old Dec 7, 2007 | 04:19 PM
sportstar91
yes there is
