caps.
Old Dec 12, 2007 | 09:53 PM
ttocs's Avatar
ttocs
Default RE: caps.
only a few more then 1k, like me.
My lights are dimming like crazy and I am in the process of getting a 200A alt hopefully with x-mas cash.....
ORIGINAL: A1SALEEN
i'm running an extra kinetic 600 battery and my lights still go dim..... but i'm running way more than a thousand watts
Old Dec 13, 2007 | 09:33 AM
joeybutts's Avatar
joeybutts
Default RE: caps.
Any of you guys hear of the Big 4? Some guy listed it in his sig on another site, but i wasn't sure if it was a joke or something.
Old Dec 13, 2007 | 10:32 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: caps.
I'd personally go with a fitted.
Most thugs tend to keep the bill straight, so I'd consider flat billing it.
Don't forget to kick it a little sideways, gotta keep it real with your homeboyz right?
Sincerely,
Your gangster friend...Hisss.
Wolfpack
Lyfe
Old Dec 13, 2007 | 10:41 AM
ttocs's Avatar
ttocs
Default RE: caps.
I think you mean a big 3 upgrade unless he has another wire he changes out. I cover it somewhere on my cardomain page.......
ORIGINAL: joeybutts
Old Dec 13, 2007 | 11:02 AM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: caps.
ORIGINAL: ttocs
caps went out with the new millenium. Spend the cash on upgrading a battery and doing a big 3 upgrade and it is $$$ better spent.
You can only go so big on an alternator. Threads like these are amusing because of the amount of misinformation on caps. The first step is to make sure like you said that your charging and electrical system is up to the task of the high output system.
1-caps do have a place but only after the first issue has been addressed. Upgrade the battery and alt along with getting the appropriate guage wires for both (+) and grounds - ground cables must be as short as possible.
2- if the dimming still occurs you can then consider caps. In order for caps to be effective there is correct way to implement them. In general 1000µf (1 Farad) for every 1000 watts is adequate. It's also better to go with two smaller caps vs one big cap (e.g. two 500µf caps vs one 1000µf cap). Those of you that really understand what a capdoes will understand why.
3- this is where most people fug up and why caps got a bad rap. The caps should be as close to the amp as possible. Meaning not at the battery of your car, not the distribution block of your amps, or even somewhere in between. 6" or less is ideal. Caps should not be shared for various amps. If you have two 250 watt amps, you will need two 250µf caps. One for each amp. The ground point for each cap should be the same as the ground point for the amp it'sconnected to. Again, if you understand what a cap is and does, you'll know why.
What I usually see people do is buy one or two huge *** caps for their system and just put them somewhere or connect them to the power distribution point. That's why they don't work like they should and they cause the headaches they do.
Old Dec 13, 2007 | 03:05 PM
seight311's Avatar
seight311
Default RE: caps.
Not so sure you know what your talking about because...
1,000µf= .001 farad.
1 farad = 1,000,000µf
And caps are still worthless, check any true champions car, whether they do dB drags or SQ competitions. They don't have capacitors for a reason.
Old Dec 14, 2007 | 03:28 PM
ttocs's Avatar
ttocs
Default RE: caps.
I would probably go with a 2nd battery dedicated to the system(after alt and power wire upgrades)before I did a cap.
Sic5OohSC
Oct 20, 2006 12:40 AM
blackout
Sep 4, 2006 10:56 AM
lbill05GT
Jul 17, 2006 10:52 PM
gneirynck
Mar 23, 2005 09:44 PM
Dejavu
Jan 6, 2005 11:36 PM
