ported vs sealed
Old Dec 26, 2007 | 03:43 AM
IDRISCKY's Avatar
IDRISCKY
Default ported vs sealed
i'm looking to rebuild my sub box, and i was gunna use ported since i hear it's a lot better.
i'm looking at the graphs that come with the subs, and basically everything is better with sealed. even at 20hz it's higher, and i think i heard that ported lose bass at lower frequencies, but make up for it at higher ones, and i'm not seeing that in these graphs.
so are ported really that good?
or should i just go with sealed?
discuss.
Old Dec 26, 2007 | 03:58 AM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Default RE: ported vs sealed
How much room do you have?
What type of drivers are you using?
How many drivers?
SPL or SQ?
Old Dec 26, 2007 | 12:39 PM
IDRISCKY's Avatar
IDRISCKY
2 jbl, 10". i have all of my trunk for space
and SQ
Old Dec 26, 2007 | 02:11 PM
Hisss04Cobra
says hiththth
I'm going to semi sum it all up for you.
A sealed enclosure is easy to build.
If you are doing the construction of the box then stop reading here and go with a sealed box.
A sealed box is an airtight enclosure.
Usually, the bigger the box, the more low end output is produced. But it comes at a price. With that price being you will need more wattage.
The smaller the box, the more controlled the excursion is.
Ported/vented enclosures take advantage of a port to amplify the sound that is being produced.
By tuning the port you effect the way the port resists motion, in a way.
By tuning a box you can net gain more decibles in output than you could using a sealed enclosure.
Like I said brotherrrrr.
Ifyou're building it, I'm going to assume you aren't a box building genius so stick with the sealed.
If you're paying someone else to do it, well then there is some information that may, or may not, help you to decide on what type of box you want.
Old Dec 26, 2007 | 06:50 PM
IDRISCKY's Avatar
IDRISCKY
ORIGINAL: Hisss04Cobra
arrite, thanks. i think im gunna stay with sealed. ported seems like it's good, but not worth the work.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
