interference
Old Mar 18, 2005 | 02:45 AM
fatguy_poolshark's Avatar
fatguy_poolshark
Default interference
Dang speakers are getting feedback in my system its kinda funny too
like i drive a 93 mustang lx w/4 banger and inside the car the deep rumbling bass feedback sounds like a 5.0 inside.... kinda cool but the other which is a high pitched crackling noise isnt... these noises increase with RPMs and arent their at all fi car is on acc.... any thought suggestion help? im running a pioneer head unit a Equalizer and 2 10 subs with a precission power amp... all componet speakers are stock but there also on a PP amp lol . This is the premium system
Old Mar 18, 2005 | 06:35 AM
Acewelder99's Avatar
Acewelder99
Default RE: interference
IT's the v8 trying to break out! LOL Sounds like noise from the alternator. Check all the conections and make sure that they are shielded. May cut down on the noise. Are you running a cap? If not that may help take some of the strain off the car battery and alternator
Old Mar 18, 2005 | 10:20 AM
rednblackdawg's Avatar
rednblackdawg
Reroute your wires away from the tranny or anything which may let noise bleed in. Also, check to make sure you have a good solid ground.
Old Mar 22, 2005 | 02:12 AM
fatguy_poolshark
any other ideas... i have my eq grounded off against the main ground for the radio... think i should run a secondary ground for it? also any noise dampeners or anything like that
Old Apr 4, 2005 | 12:47 AM
mrnolan27's Avatar
mrnolan27
I usually run seperate grounds for each piece of equipment. That should eliminate your noise. Also if you use RCA cables make sure they are not run on the same side as your power wires and make sure they are shielded cables
Old Apr 12, 2005 | 02:57 PM
Pure5.0's Avatar
Pure5.0
ORIGINAL: mrnolan27
That will actually create "alternater whine". Creating different points where the electricity can alternate will create really bad noise.
Get rid of your EQ. I have never liked them and have seen too many create noise. Get some couplings and connect your RCA that go into your EQ with the RCA that go out. IF the sound goes away then it is your EQ.
Also make sure your grounds are good. If they are on metal make sure there is NO paint there.
If you have two gounded points and one has more resistance thant the other then alternator whine is bad.
Also make sure your battery is a good battery too. Your batter, believe it or not, is the best piece of audio equipment. If it is not good then it cannot filter that noise and therefore your speakers produce it.
Old Apr 15, 2005 | 03:31 AM
gotmineNov04's Avatar
gotmineNov04
I agree with Pure... if possible ground all electrical components to the same point, one heavy-as* bolt to the chassis! If this isn't possible, do it anyway!
stark777
Sep 21, 2015 12:46 PM
geetee03
Nov 14, 2006 12:58 AM
somepolish
Oct 5, 2005 01:47 PM
