New HU and Amp/sub problem
well looks like the I have ZERO voltage coming out of any of the ports, that really sucks the damn thing worked just last week, oh well any suggestions on a new one for probably the $150 range?
well the amp was about 4 years old, just sucked it had to die when i was putting a new HU and sutff in, and what profile amp do you suggest like i said probably around 150 is my budget as of now because I just bought a procharger setup and that really put me back.
http://www.woofersetc.com/index.cfm?...roduct_ID=4871
Hope I didn't obliterate your budget too much there...
Also one you could look at http://www.woofersetc.com/index.cfm?...roduct_ID=4207
I used to work at a stereo shop and one thing we would use to test amps is get a cd/mp3 player that works. Get a headphone jack to rca output and then hook the rcas to the amp.
I see you are located in PA. Im over in philly if you are closeby and want me to take a look.
Goodluck,
~Deep
Edit**
Actually you dont really need the cd/mp3 player, its just another audio source to test see if your amp's rca connection works and if itll play music.
Goodluck,
~Deep
Edit**
yeah hey ttocs i tested ac voltage to after consulting the amp manual aswell and it has nothing at all coming out. and Deep im about an hour away from philly the stang is currently undergoing a rear rotor and caliper upgrade so its kinda out of comission atm.
http://ikesound.com/product-product_id/4349 yeah wow look at the price on this its the same hi fonics amp but its 115 instead of 178! that seems too good to be true whats up with ikesound is it a reputable company?
