D3 Popping and Sub help
Old Jan 21, 2008 | 10:04 PM
PennState's Avatar
PennState
Default D3 Popping and Sub help
Hey, i have a d3 coming in the mail, my question is that do you really need a reistior or w.e and which one exactly. Ive been reading a bunch of threads and its very confusing. Also how and where do u connect this. And i had after market subs installed so how would i go about installing that to the d3. Please any help would be great. Please if theres anything i need to know, let me know.
Old Jan 22, 2008 | 12:43 PM
ttocs's Avatar
ttocs
Default RE: D3 Popping and Sub help
the problem is that the stock deck sends out a +6v remote turn on(this is a wire that has voltage on it when the deck is on to tell the amps to turn on) for the factory amps, where EVERY other radio uses a +12v remote turn on. IF you are wiring a new deck into a mach system then you might need it if there is a turn on pop(there normally is). It does not hurt anything, it just sounds bad.
Old Jan 23, 2008 | 11:56 AM
PennState's Avatar
PennState
so i need to add a resistor.
Old Jan 23, 2008 | 09:48 PM
Boozshey's Avatar
Boozshey
yes you need a resistor.... these threads should help you...
https://mustangforums.com/m_4489289/tm.htm
https://mustangforums.com/m_4469990/tm.htm
Old Jan 24, 2008 | 10:47 AM
PennState's Avatar
PennState
thanks man,
that should help a lot
cr620
Oct 3, 2022 10:18 PM
MacSerio
Sep 27, 2015 01:05 PM
humpbackshooter
Sep 24, 2015 10:07 AM
gagemcc
Sep 22, 2015 09:43 AM
Sminemann
Sep 17, 2015 09:24 AM
