diamond audio
Old Feb 19, 2008 | 08:34 PM
Lombardo05's Avatar
Lombardo05
Default RE: diamond audio
the amp doesnt get hot at all though...i mean during the summer it does... but it usually shuts off about 30 seconds into a song when i start "jammin"... some songs dont cut out at all. and some cutt out more than they play... ill try to re-wire the subs tomorrow, and i dont think its the cap b/c it was doing that b4 i got the cap(so i bought that hoping to fx it lol) also something wierd when im "jammin" my battery icon on the dashboard lights up? ive had my dads friend come out with hims snap-on computer and he tested everything and said that the alternator never dropped below 12.8V...
Old Feb 20, 2008 | 06:59 AM
PReal's Avatar
PReal
Remove the Cap!
It does nothing for your setup but put additional drain on the alternator.
Old Feb 20, 2008 | 09:33 AM
NoLiMiT06's Avatar
NoLiMiT06
Yes remove it, it really does nothing for you. Do the following, find a new ground (not a painted surface) check wires for pinches and cuts, make sure that no bare wires are touching. If you still have problems you might have to get a new amp. And it would not hurt to get a new battery since you said the light is coming on. Your battery is prob almost drained. Head to advance auto or auto zone and have them run a battery test. It's free!
Old Feb 20, 2008 | 02:33 PM
ttocs's Avatar
ttocs
http://www.liquid-ice.co.uk/store/ca...iew.asp?item=9
Read the specs for the amp, it is rated at 4 ohm. You are completely overdriving that amp when you have it hooked up the way you do to what you have. You will need to do a series-parallel wiring system with those speakers to use that amp.
Old Feb 20, 2008 | 02:34 PM
ttocs's Avatar
ttocs
ORIGINAL: NoLiMiT06
I had a similar problem with my setup and it ended up being a bad cap,
Thats funny, let me know when you find a good cap.
Old Feb 20, 2008 | 11:17 PM
NoLiMiT06's Avatar
NoLiMiT06
ORIGINAL: ttocs
ORIGINAL: NoLiMiT06
I'm not using one anymore, no need for it. Causes more problems than solves
JoshyGT
Sep 19, 2017 08:52 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
iamgobono
Sep 3, 2015 12:37 PM
iamgobono
Aug 16, 2015 10:50 PM
89vertgt
Jul 30, 2004 02:26 AM
