problem with amp HELP
Old Feb 19, 2008 | 12:27 PM
TripleJay22's Avatar
TripleJay22
Default problem with amp HELP
i had just relocated my amp yesterday and took it off the box and moved it to the carpet and it started to overheat and blew the fuse in my wiring, after i replaced the fuse only one sub would work but i then moved both wires to one port of the amp and then they both worked great, did i fry part of my amp? or can it be fixed?
Old Feb 19, 2008 | 12:49 PM
PReal's Avatar
PReal
Default RE: problem with amp HELP
It sounds like you might have burned up a Mosfet and killed a channel on your amp.
Check your wiring and voltages to make sure you are wired correctly.
Old Feb 19, 2008 | 01:19 PM
TripleJay22
all my wiring is correct and if i killed a mosfet can that be fixed?
Old Feb 19, 2008 | 07:16 PM
NoLiMiT06's Avatar
NoLiMiT06
You best option would be to use a volt meter with everything hooked up and see if you get a signal from your channels. After you have done this and still no luck carry the amp to a local audio shop or a best buy and have them take a look at it. What kind of amp and subs do you have?
Old Feb 20, 2008 | 02:50 AM
TripleJay22
it is a rockford fosgate 1200w amp and 2 10" alpine type e's, soon to be 2 10" jl audio w3s. but i think i figured out the problem just dont know how to fix it and if it will even work after being fixed, ill post pictures in a few minutes if someone could give their opinions
Old Feb 20, 2008 | 03:08 AM
TripleJay22
here is the problem, in the one picture that small u shaped peice is missing and all together there is three missing on one side i have just placed two back in to where they will stick in good, will that work or what will i need to do to fix it??thanks in advance the help is greatly appreciated
http://i160.photobucket.com/albums/t...J1002/amp2.jpg
http://i160.photobucket.com/albums/t...J1002/amp1.jpg
Old Feb 20, 2008 | 07:14 AM
PReal's Avatar
PReal
That is a resistor and you will not be able to just stick it on there. You need to remove the board and resolder the connection.
Old Feb 20, 2008 | 09:39 AM
NoLiMiT06's Avatar
NoLiMiT06
Yea just resolder it hopefully the resistor is not blown itself.
Old Feb 20, 2008 | 02:28 PM
ttocs's Avatar
ttocs
please do not go to best buy. There are a COUPLE of ok installers in their 10000's of locations but otherwise they will hire almost anyone.
ORIGINAL: NoLiMiT06
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
