what are...
Old Feb 27, 2008 | 11:21 AM
  #21
joeybutts's Avatar
joeybutts
Default RE: what are...
So the 19Ov.2 I stuffed in a tissue box won't sound good? Is that what you are saying?[8D]
Old Feb 27, 2008 | 02:22 PM
  #22
disturbed471985's Avatar
disturbed471985
just duck tape the edges to make it air tight
Old Feb 27, 2008 | 08:38 PM
  #23
seight311's Avatar
seight311
It will sound fantastic, bascially a nice small, tight enclosure. Plus you have the best type of polyfill that exists, an old SPL competitors secret, known only by veterans.
Old Feb 28, 2008 | 01:42 AM
  #24
pk222's Avatar
pk222
The reason that 2 different sized subs dont sound good together is because they have different wave lengths which makes the combo sound bad.
And there are so many factors on your spl its rediculous, so unless your planning on competing, does it really matter? all your going to get from an spl set up is loud distorted bass. Wouldnt you rather have it not as loud with way better sound quality?
one of the subs I think you would like would be the fi q ficaraudio.com, Your amp is a little small for it though. You can make almost anything loud by putting it a one note wonder box but who would want that for the street?
Old Feb 28, 2008 | 08:19 AM
  #25
07lane40's Avatar
07lane40
im putting them on two different amps (10's on the 1000 and 12 on the 750), so ive been told it will respond and sound just fine. im not planning on competing, im just wondering how loud it will be. theyre going in sealed boxes, and as far as im getting the same stuff as my friends, im not, im running two amps and thyre just ruuning their single 1500's. im getting it done no matter what. and im going for quality, not just dbs if you read my ealier posts, im just wondering how loud it would be.
Old Feb 28, 2008 | 08:36 AM
  #26
disturbed471985
well ok running them off diff amps makes no differnece you will sound like ***. and sq is what you want??? if so change all your plans. who told you it would sound fine?? cause they lied to you. but it seems your going to do what you want so really dosent matter what anyone says.
like said above 130's maybe but ull sound like *** at any level so that dosent matter.
Old Feb 28, 2008 | 09:14 AM
  #27
joeybutts's Avatar
joeybutts
ORIGINAL: seight311
$hit! You mean i need to put the tissue back in the box??!?! Is it ok if they are used?
OP, are you not reading what everyone has written? You just went back on what everyone has just told you. no matter what, unless you use some serious processing and really understand what you are doing, multiple subs is not going to work the way you want it to. and even then it isn't worth it!!! you may get some great SPL but other than that, your SQ will be in the garbage.
Old Feb 28, 2008 | 09:45 AM
  #28
disturbed471985
used ones are better they stick to the sides of the box to make it even more air tight kinda like snot caulking. If he understood what he was doing then we wouldnt be having this convo but hey i guess he can tell his friends look 10's and 12's just plz dont turn it on unless you like the sound of big ole floppy *** clapping.
Old Feb 28, 2008 | 09:57 AM
  #29
joeybutts's Avatar
joeybutts
*** clapping is only acceptable in three places.
1. The bar/club
2. The bedroom
3. The Strip joint
Big ole floppy *** clapping is NEVER acceptable.
Old Feb 28, 2008 | 11:24 AM
  #30
Unforgivine's Avatar
Unforgivine
If you want clarity kickers aint the best i wont got with a 12 and a 10 sometimes the 12 will pushing the 10s ith the 12 is powerful enough but jl is better then kicker
