2 awg terminals same as 0awg terminals?
Old Feb 29, 2008 | 11:35 PM
lundis's Avatar
lundis
Default 2 awg terminals same as 0awg terminals?
i was given a ****load of 2 gauge power wire, so i dont wanna go out and buy zero when 2 gauge will suffice... but im having difficulty finding regular terminals to fit it.
will the screw-down terminals made by a company like stinger,(something like this) fit a 2 gauge, or will i have to worry about it falling out?? ive only ever worked with zero, or 4 gauge before, and both my amps need 4 gauge, so i dont want to run a main power wire of 4 gauge!!
thanks to all those that can give me some input!
Old Mar 1, 2008 | 04:41 PM
apolnerow08's Avatar
apolnerow08
Default RE: 2 awg terminals same as 0awg terminals?
If it says it takes0awg for something, the best wires to use are 0, 2, and 4 awg. Any other gauge will work but youll just screw it tighter to fill the connection.
Old Mar 1, 2008 | 08:43 PM
ttocs's Avatar
ttocs
if you use something like that with a screw that tightens it will hold it will just look as silly as you did at age 5 with your dads shoes on.
http://www.knukonceptz.com/is a great site for misc connectors at descent prices.
what amps are you runnin
Old Mar 2, 2008 | 02:02 AM
lundis's Avatar
lundis
i found a 0 awg kit for less than 50 bucks on darvex.com, so i just figured, screw it.
running 2 hifonics amps, zeus series, one pushes 110x4 @ 2ohm, the other 500x2 @ 2ohm. both have 4awg terminals for power and ground.
now that the 0 kit is coming, going to run the 0 for power down the center console, under the carpet, and under the back seat, through a fused distro block, splits it into 2 4 awg outputs, should work just fine.
admin/mods can delete/lock this thread as its no longer necessary.
Old Mar 2, 2008 | 02:13 PM
ttocs's Avatar
ttocs
you are going to have fun running 0 awg through you consol. I ran 4 awg and put my dist block in the consol and it barely fit. it is somewhere in my cardomain page if you want to get ideas.
Bokeo
Oct 10, 2015 08:28 PM
logan409
Sep 26, 2015 07:43 PM
SteelerNation82
Sep 16, 2015 07:11 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
