mach 460 not workin
Old Apr 7, 2005 | 11:18 PM
BewareOfBite's Avatar
BewareOfBite
Default mach 460 not workin
aight well i tried to hook the subs up to my mach 460 using that line out converter and now my radio doesnt even turn on. i checked all the fuses and they are fine and everything is hooked up like it needed to be. anyone have this problem when settin up subs this way?
Old Apr 12, 2005 | 02:41 PM
Pure5.0's Avatar
Pure5.0
Default RE: mach 460 not workin
Does your radio turn on just no sound? If so then you are grounding a speaker.
If the radio does not turn on then you blew a fuse or have exposed wires somewhere. Not just the radio fuse blows if your radio does not turn on.
There are two power wires for a radio to turn on. Batt and Ign. The Ign will be the fuse you might assosiate with the radio not turning on. But the Batt wire will be fused with the domelights.
Check all fuses with a voltmeter. There are fuses in the car and under the hood.
Make sure that all your wires have electrical tape and that no wires are exposed. They check ALL your fuses. Pull them all if you don't have a voltmeter to check them.
Also if you do have a voltmeter and dont' know how to check...set the voltmeter to check continuity. This is usually with the ohms and has a sound icon. When you touch to the leads together you sound get the meter to beep. Then check all fuses by the exposed metal on the side. If the meter does not beep then there is no connection...bad fuse.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
