conv. wiring repair?
Old Apr 9, 2005 | 01:24 PM
unobigrhino's Avatar
unobigrhino
Default conv. wiring repair?
hey guys. im a newbie and just bought a 97 GT conv. and i have been fixing it up but the only thing that i dont know how to do it find out whats wrong the the top motor. so i was wondering if you guys knew any common problems with them that i could check. also, how do you get the speaker covers off. cause i dont want to break them. thanks
Old Apr 9, 2005 | 06:12 PM
Jimmz's Avatar
Jimmz
Default RE: conv. wiring repair?
If your top doesnt work (go down or up) then the motors gone and you'll have to get a new one. I had the same problem with my old 85 5.0. As far as the speakers go youll have to take the whole door panel off. You just get a flat head screw driver stick it inside the window switch panel (theres a little whole on the top) youll see it. The it will pop off unscrew the wiring harness then grab the sides of the panel and it will pop off but be careful cuz you might break one of the clips on the door. Then youll see the speaker, take it out and pop the new one in, connect the wires to the speaker, connect the switch harness, put the door panel and window switch panel back on and your all done. I did it to my 2003, and it took me 15 minutes to install both door speakers.
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
b8checker
Sep 30, 2015 07:11 AM
