Splicing In!!!!???
Old Mar 25, 2008 | 05:32 AM
blkthndr03's Avatar
blkthndr03
Default Splicing In!!!!???
im getting a bazooka bass tube for a lil more bass to accompany my factory mach460 system i dont like it too loud so a single 200 watt 8inch should do it. i really dont like running wires inside my car im more than capable of doin it i just dont feel comfortable rippin my baby apart and runnin heavy gauge wire through it so i was curious couldnt i just splice into my power wires and the speaker wires for the mach460 amps and run it that way if this can be done please let my know and direct my to a good wiring diagram.
Old Mar 25, 2008 | 10:37 AM
ttocs's Avatar
ttocs
Default RE: Splicing In!!!!???
nope,will not work. The wires are too little for just your amp, let alone the mach. You will need to run all the proper wires, fused with in 12" of the battery. The signal can be tapped at the back of the enclosure so the power wire is all you will, have to run.
Old Mar 25, 2008 | 11:35 AM
850SN95's Avatar
850SN95
correcto! mundo!
Old Mar 25, 2008 | 09:37 PM
blkthndr03's Avatar
blkthndr03
so basically thats all i need to run is the power wire from the battery to the trunk and i can splice into the factory speaker and remote turn on wires and ground to the frame
Old Mar 25, 2008 | 10:31 PM
ttocs's Avatar
ttocs
unfortunatly the remote turn on will not work since the factory amps use a 5v turn on and your amp will require a 12v. You can run a wire to the fusebox or to the back of the radio and use the +12v ignition.
Old Mar 26, 2008 | 01:51 AM
blkthndr03's Avatar
blkthndr03
sh*t nothing could ever be just easy its gotta be difficult ill just let my brother in law do it he likes doing that stuff
Old Mar 26, 2008 | 01:53 AM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Colin Ringle
Sep 15, 2015 09:27 PM
Ford_Dude
Sep 15, 2015 03:25 PM
Nevada95
Mar 17, 2006 10:18 AM
02pnygt
Mar 11, 2006 10:56 PM
greenday3437
Feb 24, 2006 07:47 PM
