running wire in 08
Old Apr 11, 2008 | 10:50 AM
gixxer6's Avatar
gixxer6
Default running wire in 08
I was wondering what is the best way to run power wire, rca's and and such to the trunk in an 08 GT with the none shaker system.
thanks
Old Apr 25, 2008 | 11:16 AM
sp44's Avatar
sp44
Default RE: running wire in 08
I'd run power/remote turn on down the right side and rca's on the left.
Old Apr 25, 2008 | 08:59 PM
ttocs's Avatar
ttocs
you do not need to seperat the remote wire from the rca's. You will commonly see cables with a single wire built into it for this reason, it is a low current wire that does nothing more then turn on a relay. It does not draw enough current to make noise in the cables.
Now it is common to seperate the power and rca wires, but you do not have to worry about seperating the power from the speaker wires.
Old Apr 27, 2008 | 03:59 PM
gixxer6's Avatar
gixxer6
Yea i just ran all my wires but i couldnt find an easy way to get the power wire through the passanger side firewall. Did you drill a hole or is there one already there
Old Apr 27, 2008 | 10:01 PM
ttocs's Avatar
ttocs
most people go down the drivers side, although I have not had my head under the hood of a new body style to know if the battery is on the other side. There should be a grommet but sometimes you do have to drill.
Old Apr 28, 2008 | 03:58 AM
JTE_502's Avatar
JTE_502
Just had the amp and sub put in the trunk of my 08 a few weeks ago. I used 0/1 gauge wire and we ended up just cutting a hole in the passenger side of the firewall for the power wire, and ran the RCA's down the driver side.
Old Apr 28, 2008 | 10:14 AM
sp44's Avatar
sp44
ORIGINAL: ttocs
Yeah battery is on the passenger side.
2007StangV6
Jan 28, 2016 06:09 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
