shaker 500 door sub replacement
as you know, the shaker 500 has 2 8" door subs, shallow i assume. can you replace these with aftermarket subs or would you need an amp, or would the factory amp be enough
Theres a lot of information on this already...
actually, if you look farther down the page, i know of at least 1 other thread addressing this issue.
Searching does wonders.
ok, maybe i will ask somebody that would be more helpful. i searched crutchfield for shallow 8" and it came up with one, a kicker i think. i am not sure about ohms. what is the factory ford. or can somebody give me a part number to the rockfords that seems to be a popular replacement. thanks
i'd like to know if i could use these
http://madisound.secureserverdot.com...oducts_id=1405
i did a little searching on the forums and never did find how many ohms the factory subs were, or how many watts the 500 system pushes to those subs
I believe I read somewhere on this forum that the subs were 8 Ohms while the 6 x 8's are 4 ohms, but I don't know for a fact about the subs. You can use the search function.(My 6 x 8's are 4 ohms in my car).
hmm, well scratch that idea. the whole reasoning behind it was because the factory subs are produce a nasty rattle, and its annoying, and its far from max bass too. thanks for letting me know before i went to best buy and just started buying away
ok, it worked that time, i just checked, it says 4 ohm on their website. i know next to nothing about car audio and terms used with. a salesman could really get me if they wanted to. thanks again everyone
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
2007, 2008, 500, 8, audio, door, doors, mustang, replacement, replacements, replacing, shaker, subs, subwoofer, subwoofers
