hooking up an amplified bass tube
Old Jun 15, 2008 | 05:11 PM
01GT4.6's Avatar
01GT4.6
Default hooking up an amplified bass tube
I got an amplified bass tube for fathers day and wanted to hook it up in my '09 Corrola. Can I just wire it to a rear (back deck) speaker or do I have to wire it to the radio? If so how do I do it. I'm sorry but it came with no instructions and I don't want to pull the radio if I don't have to.
Old Jun 15, 2008 | 07:59 PM
PReal's Avatar
PReal
Default RE: hooking up an amplified bass tube
You are going to need a 3 primary wires and then the signal input wires.
You will need a 12V power and ground, a 12V switched power to turn the amp on, and an input signal.
You may be able to find a wire in the trunk that is12V switched power, but you are going to have to run a power wire from the battery. The negative goes to chassis ground. if your bass tube can handle speaker level inputs you can run those from the rear speaker.
Sorry, but I think you have a lot more work then expected.
Old Jun 15, 2008 | 09:20 PM
ExtrmZ's Avatar
ExtrmZ
so is it like if you were to hook up an amp?
Old Jun 15, 2008 | 11:16 PM
ttocs's Avatar
ttocs
exactly the same except you do not have to run wire from the amp to the speaker. IF it has a high level or speaker level then you can use the rear speakers as your signal source but you may have noise.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
BrantleyS550
Sep 14, 2015 04:18 PM
