can i hook up this head unit?
Old Jun 21, 2008 | 05:07 PM
simpsonfan13's Avatar
simpsonfan13
ELEKTRO-FIDE Moderator
From: In Geo-synchronous orbit over redass' bathroom,
Default can i hook up this head unit?
like the title says, the pic up top is of the only cables coming out of the car.
the next one is the one coming out of the steree.
im not sure if i can just hook it up. or what i should hook up.
if you guys need more info let me know.
Old Jun 21, 2008 | 06:33 PM
ttocs's Avatar
ttocs
Default RE: can i hook up this head unit?
they should plug into each other(grey and blk/grey). Looks like the deck is a passive unit that has no amp built in so you will need to supply amps.
now at the top of that pic you can see the ford factory amp(this looks like a fox body dash?) that you will need to bypass if you want to use the factory speaker wire. IT is easy ty bypass by following the hrns's that go to it. One will go up and behind the glove box and have two hrns's that are connected, that look exactly like the black hrns you already have pictured. If you disconnect those hrn's, you can pull the female end up into the radio hole and use that one as your new speaker hrns, and you just bypassed the amp.
I show how to do something similar on page 2 of my cardomain page but the same hrns is in a different location for my 94 gt.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 30, 2015 03:48 AM
