replaced door subs!
Old Jun 23, 2008 | 11:03 AM
06elnr's Avatar
06elnr
Default replaced door subs!
I put in the door subs today, I will try to do a write up soon...
Old Jun 24, 2008 | 01:53 AM
cartel's Avatar
cartel
Default RE: replaced door subs!
Nice, are they Dual Voice Coils? What depth are the speakers? I assume they are the regular 8". I have found a few shallow mount speakers in 8" to fit this space. Did you use the screw hole in the rear? Are you using a seperate amp for your subs? You can cheat some space by cutting out the cone with the center hole in the rear and gain about 1/2 aninch, but you will have to seal the hole afterwards.......Im working on mines too.
Old Jun 25, 2008 | 10:52 AM
SumterBoy's Avatar
SumterBoy
What kind of subs are those.
Old Jun 27, 2008 | 10:45 AM
GTRedfire03's Avatar
GTRedfire03
Looks Good.
What are then Kickers?
Old Jun 29, 2008 | 09:21 PM
06elnr's Avatar
06elnr
yes they are the kicker ss series, I used the factory trim ring and fiberglassed over it and took out the old sub and mounted this one to the fiberglassed trim ring and put it back in it was very simple...
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
SYNY5TER
Sep 2, 2015 01:35 AM
