Radio Static AM while running - 94 Vert
Old Jun 27, 2008 | 11:20 AM
michiganman5's Avatar
michiganman5
Default Radio Static AM while running - 94 Vert
Hey all,
I have a 94 Vert 6cyl that was sitting for 2 years under a wet tarp. Had several rust issues (under seats, floors, fuse box etc). when I bought the car there was no stereo in it. Just the CD Player as part of the Mach 460 stereo cd system (i think).
Anyway, I went to a Mickey Shore and said I wanted a stereo. Bought an Alpine stereo with the extra connector to connect directly to the original system (without using the cd of course). took the guy a while to get it going, the connectors were a bit corroded. But he did get it to work. sounds pretty decent (speakers probably need to be replaced, but ok otherwise).
The problem is when I turn on any AM station. There is a high pitch sqeel, or wine i guess that gets worse when I rev the engine. I changed my antenna thinking that may be the problem (first with an aftermarket cheapo, then with an original antenna off another car), but it's still bad.
Then I noticed when the car is off, the stereo sounds GREAT. apparently I have a problem with a ground, or maybe corrosion in the wires maybe?
Someone suggested my spark plugs need to be Non resistor types??????????
Any help would be appreciated!
Thanks,
Jay
Old Jun 27, 2008 | 05:03 PM
ttocs's Avatar
ttocs
Default RE: Radio Static AM while running - 94 Vert
sounds like it was under water or had a bad leak?
Do you know if you still have the factory amps/woofers working? I would start simple and check your ground and power connections. On my 94 gt a noticed a couple of years ago that the factory ground(right next to the battery) had developed some corrosion and causing problems.
If the antenna was close to the plug wires I would be worried but...
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
cbird1177711
Sep 3, 2015 08:43 PM
